Microwave Ovens Logo
Posted on Sep 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a panasonic NNA883w combi microwave oven. The microwave part has stopped working. The unit dows not turn switches off after three seconds without warming anything. The oven and grill elements still work.
William Miller
Level 3:
  • Panasonic Master 9,179 Answers
  • Posted on Sep 25, 2008
William Miller
Panasonic Master
Level 3:
Answers
9179
Questions
Helped
4481480
Points
21747
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
You can find an authorized Panasonic servicer here.
1helpful
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
1helpful
My turntable on Panasonic NNA883W combi oven has stopped working is it easy to fix it just freely turns with no resistance
Usually underneath the plate is a square or triangular spigot which should fit into the plate recess these are usually plastic but some are ceramic in combi ovens and are prone to breaking.if you can't lift out the spigot from inside oven to inspect...then you may need to gain access the the bottom of microwave.always disconnect appliances from power supply before removal of internal/external parts.
I have a neff combi microwave oven and it stops working after 20 seconds and doesn't heat the food
It is one of three things, the microwave oven, "heart of the system" inverter board, "if less than 7 years old" and the keypad control board. all parts mentioned are not cheap.
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
My panasonic nna770s combi microwave cuts out after 3 seconds during this time the turntable doesn't turn, any ideas?
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
If you;'re not in the US or Canada, see the support or service links at www.panasonic.net.
4helpful
Comes on for 5 Secs
Hi I am Vortash sounds to me as if the Magnetron is burning out and the heat sensor switch is turning the unit off as the mag gets hot ? .. you can get a cheap replacement of ebay but to be honnest microwaves are so cheap now you will probably get an oven for what you would pay for a new magnetron .. Regards Vortash
1helpful
2answers
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Panasonic Microwave Problem
Even though these are different symptoms, the same part may be causing both.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
2helpful
4answers
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
