SOURCE: LCD Samsung Syncmaster 740n 17... Fuse F301 is brocken.
You still have shorted out components on the circuit board, you will need to download tha service manul here to do an indepth troubleshooting: http://elektrotanya.com/
SOURCE: Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine
what's wrong with your LCD monitors. After you turned it on and the screen
blacked out or stopped working, you have to check that if you can see the image on the screen or
not by shining a flashlight into the screen, not directly but find the best
angle to the screen and take a look very closely. If you can see the icons or
any image, there will be a minor problem. This is because of the lamps inside
screen. Some of them were broken and it is very easy to replace. If you cannot
see anything on the screen, there'll be some problems with inverter board. If you
have soldering tool and want to fix it by yourself, check the caps first. It
may cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
SOURCE: Driver needed!
Download driver from Samsung:
http://product.samsung.com/cgi-bin/nabc/support/b2c_downloadcenter_detail.jsp?eUser=&mobile=N&oid=71250&cntType=DR&cntId=181761&lang=ST
SOURCE: My samsung Syncmaster 940mw wont turn on when the pc is turned on
Your needs internal servicing by experienced person. Capacitor or ERT may be malfunctioning
