Cd remote changer does not play and cannot eject the cd that is in the magazine
A lot of times there is a gear inside of the changer that gets jammed. If you can, remove the top cover of the changer. On the changer mechanism (it will be on the right side of the changer) there will be a large gear (probably black) with an arm attached to it. Use a flat blade screw driver or something like that and turn the gear counterclockwise until the tray is back in magazine. You should then be able to put the changer back together and it will probably work fine.
