Take mp3 from ur computer then copy to ur folder (ringtone) and rename it to the song that u want to delete..:) then go to ur fhone>files>ringtones> then delete the copy folders..> and the protected folder will be unprotected.> delete again...and uu r succesfull to delete the protected files.:D..:D..its work on me ... i hope it's work on u too..
You cannot delete the default ringtone, still if you want to delete the saved downloaded ringtones just go to the saved location and in options you will find delete.
hope this helps, please rate and leave a comment if the solution was helpful ,thanks!
HI Prabin Thapaliya are these ringtone that you downloaded? Ok first thing you will need to do it is bring up your menu. Next thing you can hit the music player and see if your ring tones are there. If they are not their go to my files. Look for a file named ringtone go through it. Hold the ringtone until you get a menu that has a list of actions you can do. Delete should work for you to get rid of the old ringtone on your phone. If you want a detail direction on how to find and use any features on your phone. Go to Samsung .com for a the phone's manual. Hope this help.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
I can delete ringtones from my phone
Well... further clarification needed to provide a perfect solution to you. If you are trying to remove the system ringtones, you might not be able to do so as the manufacturer place these tones in the rom area of the phone and you might not be able to do so.
However if you are trying to remove other kind of tones, there might be a possibility that these tones are saved on your memory card and your card is write protected. In the situation try removing the write protection from your card. If you are still unable to delete it off your card, then try taking out the card, and manually deleting them through a computer using the adapter or a micro sd reader.
