The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Look at the label on the rear of the Creative SBS and make sure the 240v adapter you use matches what is stated there. eg. 9v d.c. 500ma
Provided the plug on the adapter fits in ok and the voltage is correct you must use an adapter with the minimum stated "ma" (milliamps). You can however use an adapter that has a greater "ma" capability....say up to 750ma, BUT you must not exceed the "v d.c." (DC voltage) rating.
As long as it is thesame with the specification of your old adapter. Better to check the voltage and the amperes of the adapter from old to new. Thanks. Hope it helps.
SPECYFIKACJA :
