Good Day;
Turn your color down all the way, do you get a good Black and White picture with good black, white and grays? If not your picture tube may be going bad. It can be adjusted sometimes to get a 'better' picture.
If picture is a good B&W; adjust britness level: 50% > contast: > 90/95 % >color: 50%.
Good Luck, big IRISH.
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
