Samsung TL100 / ST50 Digital Camera Logo
Anonymous Posted on Nov 01, 2011
Why my ST50 Samsung camera cannot work even after battery being charged. If I put on photo taking or video icon it will beep and then it gets turn off. Thanks Helen
damneddle
Level 3:
President:
  • Master 1,607 Answers
  • Posted on Nov 01, 2011
damneddle
Master
Level 3:
President:
Answers
1607
Questions
Helped
336416
Points
4892
It could be a lens error or battery already malfunctioning. Do you get any error message or any message at all before it turns off?
  • Anonymous Nov 01, 2011
    No error message. After playing with it, now the len is freeze it cannot retract back.
    Please help. I now don' t have a great deal of good opinion on this camera.
    Look forward to your solution. Thanks.
  • damneddle
    damneddle Nov 02, 2011
    Hello again Helen,
    So, it is lens malfunctioning. It is possible that something might be stuck inside the lens mechanism (like a grain of sand) . Try holding your camera with the lens facing the ground and then tap your camera repeatedly. You can also try applying canned air through the lens.
    If that doesn't solve your problem, you will need to bring your camera to a repair center and possibly, you might need to change the whole lens.
Samsung Digimax S800 camera won't turn on. Beeps three times.
This explains the 3 beeps. also says you can get it repaired which is by far the best option. The behaviour is very typical of low battery state. Try a set of Lithium batteries.
https://www.samsung.com/in/support/cameras/why-camera-goes-off-after-3-beeps/
2 beeps
Always first check the battery. Switch off the camera, remove the battery and charge the battery. Then try again. Sometimes, even when the charger indicates the battery is charged, it can be the battery does not have enough power. If the camera does not work, even after charging the battery, contact the service centre closest to you.
My cameras batteries are dying after me putting them in fully charged after 5 mins it conks out
I am getting trouble to get photos from my Samsung Digimax A400 Camera......... Kodal Sd Card 128mb Its says this but i do not understand !!!!!!!!!!! Plzzz Help ME :)
2answers
When I take a photo, it just shows white on the screen and each photo is white when I view them. However I can still take videos just fine! whats wrong with it? It is a Samsung ST50
Hi you have very interesting problem. It seem to me just lens unit defective. What I can tell between camera picture mode work and video mode work are depend on how mechanical shutter unit and electro shutter signal work. It is kind of technical thing to figure them out. Maybe I am wrong, but I sure also. Thanks and best regard!
Samsung TL205 Battery Charger http://www.samsung-battery-charger.com/Battery-Charger/Samsung-TL205-Battery-Charger.html Samsung ST50 Digital Camera Battery...
What a battery of information you have accumulated - you must be a bright spark. Please put a plug in it now.
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
S800 lens won't close, can't take photos
The lens was bent to one side, so bump with my palm to straighten it back. I was able to start using my Samsung again.
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Wont stay on
You probably don't have the batteries fully charged up. Also you will need to change battery type from alkaline to metal hydride in the "wrench2"(the last icon on the menu) menu. You did get metal hydride rechargeable batteries??? If you got nickel-cadmium rechargeables that might also be your problem with your camera as they don't have enough power.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
