It is normally the element that has gone, located behind the fan. A long shot could be the thermostat. Have a look at the thermostat sensor. It will be located in the oven at the back somewhere. It should be clean and bright and not covered in dirt or grease etc. If it needs a clean, use a spray cleaner and do not treat it to harshly. The thin wire leading from it is quite fragile! However, if you decide to replace the heating element, I would suggest that you replace the thermostat as well because quite often the element blowing damages the thermostat, which could lead it to fail, it it hasn't already done so, at a later date.
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
