Usually this is an indication that your camera is broken. When the phone tries to access it, it can't so it the application crashes.
pull the battery and let the phone rest for a few minutes. Put it back in and start the phone, if it still doesn't work then its not a software related problem or glitch, but a physical problem with the camera or its connection. It won't be an easy fix for a consumer to do.
hey
May be there is some problem wth your mobile software plz chek this website http://www.nokia.co.in/get-support-and-software/download-software/phone-software-update?N70=# and download Nokia Software Updater in your pc
after installing this software connect your phone with your pc or laptop and run the Nokia Software Updater after doing this your phones takes 5 to 10 minutes to update in between this process dont touch your phone , one more thing plzzz check the battery of your phone is charged
check the battery is it charged.if not , then charge the battery and check out.if the unit is not getting charged then battery needs replacement.you can get replacement battery from nearest nokia service center.
but if you have connection problem in your nokia for internet services then try this as follows:- Right click My Computer, go to Properties and click the Device Manager, then select Modem... disable the built-in modem of you laptop whileNokia N70 USB modem is enable. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Switch off your phone. Remove battery & sim card.
Leave the phone for 30 minutes & set them again.
It will automaticly Hangout.
Precaution- You should not keep more application in standby mode.
