Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again.
Add 1 cup white distilled vinegar to a large pot of water, bring it to a
rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing,
as well as those left by deodorants, by spraying full-strength white
distilled vinegar on underarm and collar areas before tossing them into
the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy?
Pour a few cups of white distilled vinegar in the machine and wash the
clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes
by filling the bathtub with very hot water and 1 cup white distilled
vinegar. Hang the garments above the steaming water and shut the door so
the steam can penetrate the fibers.Keep the steam iron clean and in good working order by
getting rid of mineral deposits in steam vents and spray nozzles. Fill
the water chamber with a solution of equal parts white distilled vinegar
and distilled water. Set it in an upright position and let it steam for
about 5 minutes. When the iron is cool, rinse the tank with water,
refill and shake water through the vents onto an old cloth. Test before
using.Remove scorch marks from an iron by
rubbing it with a warmed-up solution of equal parts white distilled
vinegar and salt. If that doesn't work, use a cloth dampened with
full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry!
Add about 1/4 cup white distilled vinegar to the last rinse. The acid
in white distilled vinegar is too mild to harm fabrics, yet strong
enough to dissolve the alkalies in soaps and detergents. Besides
removing soap, white distilled vinegar prevents yellowing, acts as a
fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine
with white distilled vinegar. Periodically run the machine with only a
cup of white distilled vinegar in it-nothing else added to the wash
cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline
when you take out the hem of any garment by moistening a cloth with
white distilled vinegar, placing it under the fabric and ironing.
SOURCE: How do I clean washing machine to eliminate dark
As we have not been told the make and model I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Maintaining a clean washer helps to ensure that the laundry looks its brightest and smells its freshest.
Follow a few simple strategies on a regular basis, and your washer will produce the results that you want.
Fortunately, most of these cleaning steps are only necessary on an as needed basis. If you prefer, complete most of them once a month for a sparkling clean washing machine. Follow these helpful pointers.
Goog luck.
