Keep having to adjust cooking times/heat. Lots of heat coming from top of over - is that normal?
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
