If the speakers are healthy, the amplifier driving the speakers may have failed. The output to earphones may be coming from a lower power level point prior to the power amp for the speakers. Most audio is handled by an integrated circuit that has both preamp and power amp in one package and the preamp may be OK while the power amp can fail alone.
Yes it seems confirmed that the amplifier within is in order and what would have gone wrong is the speakers within the unit. If you can open the laptop carefully sometimes it can be due to a mounting issue , otherwise a fault on the speakers coil or diaphragm, try and tap off dust ,press the diaphragm few times to make it move freely, if not you must find the same type replacement or will need to change them as a pair so as to sound equal.
