SOURCE: roper washing machine roper rax7245kqo
more than likely something is jamming your pump now your coming up on the post with another user as having the same problem but its not the same kind of machine im getting ready to answer the first user who has a front loader and it may pop up to you so disregard that. Reply to this message and ill tell you how to check yours
SOURCE: timer malfunction
No recalls are listed on the Whirlpool/ Roper web site on ant timers. Try www.repairclinic.com , If your timer isn't the problem, you can send the part back for a refund.
SOURCE: Roper washing machine not going through rinse cycle.
Good Morning,
Sounds like your cold water valve is not opening. If you are handy with a Multimeter check the selector switch that you use to set your cold water for good continuity when you activate it. You should have a good steady reading on the meter. If the meter is fluctuating or has no reading at all the switch is bad. If the switch checks out good, check to see if there is voltage to the cold water valve terminals when the machine is calling for cold water. If there is no voltage, you will have to locate the relay or source that supplies this voltage and replace it. If there is voltage the valve is faulty and needs to be replaced.
I hope I helped you today.
SOURCE: roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
