Mitsubishi VS-70707 70" Rear Projection Television Logo
A
Anonymous Posted on Oct 29, 2011
My Mitsubishi Model # is VS-70803 and is not VS-70707 Main Menu Set-up frozen on Screen unable to remove. Remote control has home to exit main menu as it will not exist from screen,Also front of TV has rest button when press nothing happens. Projection Television will turn on and off by itself after a min. or two. Change Battery on remote which seem to work fine. I purchase my Mitsubishi VS-70803 on Oct. 3,1999 and Serial No. 101836 The TV Owner's Guide on Troubleshooting Problem do not say anything about frozen picture of Menu Screen. Need Help :Thanks
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Oct 29, 2011
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718598
Points
48227
I know who answered the other question, do you want to attempt the hard reset for this model?
  • 2 more comments
  • Anonymous Nov 23, 2011
    with out addional cost yes would like to attempt the hard reset for model vs-70803
    what do you mean by additional cost?
    At no cost ! To to share or help with problem to attempt hard reset
    vs-70803 has three hidden menus that are all accessed by using the Mitsubishi remote:
    Menu 1370 takes you to option menu--hard reset is there, Menu 2357 takes you to adjust menu (be careful) and menu 2359 takes you to tech convergence menu(again be careful)
How can I get out my gld TV stuck in the USB setting
most likely you can press either the 'Menu/Select' or 'Home/Return' buttons located on your remote control to exit the USB setting and return to the main menu. If you do not have a remote control, try unplugging the power cord and waiting for at least ten seconds before plugging it back in. Then use the in-TV controls buttons to try to exit the USB setting and return to the main menu
tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
9helpful
3answers
When the TV is on we can only get the sound of the cable box but no picture, unless we have the menu up. However, when we turn it back to the main screen there is no picture. There are only to input...
IF YOU HAVE THE ORIGINAL MITSUBISHI REMOTE YOU CAN DO A HARD RESET OF THE SET.
IT WILL RETURN THE SET TO THE CONDITION IT WAS WHEN NEW IN THE BOX.
RESET FOR THIS MODEL IS: WITH REMOTE :
MENU, 1,3,7,0 ENTER.
LET ME KNOW WHAT HAPPENS AND if this information has helped you decide what to do rate this solution as "very helpful" as I do this here for free.
SD TECH
1helpful
Forgot code to unlock channels. How to unlock?
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
50helpful
2answers
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Menu button won't work
The codes that are provided to operate the tv from a Dish remote will not offer full functionality with most TV's. The menu button on the Dish remote even when able to bring up the menu screen on TV's is unable to navigate the menu screen due to the complexity of the TV's set up. The newest receiver that Dish has on the market is the 222k which is a dual tuner/two room HD receiver without DVR that has LEARNING REMOTES that might be able to accomplish the goal you are trying to obtain. I hope this answers your question and remember to keep the original TV remote in a safe place so that you can use other functions on your TV as well. Thanks for using Fix Ya and let me know if I can be of further assistance.
Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
MENU
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
CANCEL ENTER
. Press _ to set the passcode and go to
theV-chip ratings menu.
MENU
4. To exit without entering a passcode, press _ to
HOME
go to the previous menu or _ to return to
television viewing.
IMPORTANT
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
• cancel the lock.
MENU
MENU HOME
IMPORTANT
65
1helpful
2answers
Child lock is on
can you please help me unlock the personal code password for a mitsubishi vs-5003r tv.
1helpful
No code
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
