Not totally. It could be the switch but I'd look at the motor first. Disconnect the motor and running with battery voltage. If it still runs slow it's the motor. Becareful with the switch it looks like a static sensitive switch and needs to be worked on at a static free work station. The motor part # is 492829-00 Cost $92.72 The switch is 368832-09 $ 48.91 . Those are suggested list prices may vary! Good luck!
SOURCE: Jobmate 18 volt chordless drill charging
I dont have any information on this drill but most cordless products that I deal with the charge time is usually around 1 hour. Do you still have your owners manual that should be in there. Hope this helps
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
SOURCE: chuck needs to be removed from 18 volt right angle drill
OK without a model number I will try and help the best I can. First off did you get any wrenches with this kit, possibly an open wrench and a hex wrench. What you would need to do it remove the chuck retaining screw it is left hand thread and if this drill has a high and low gear selector put in low. If your spindle has a hex that you have a wrench to fit it put it on the spindle, if this is a keyed chuck use your chuck key and place the chuck and drill assembly on a piece of wood or workbench and have the wrench about a 30 deg. angle and hit it with a hammer counterclockwise to loosen, you might have to hit a couple times. If this is a keyless same thing except find an allen wrench about the chuck capacity and lock it in the jaws at about the same 30 deg and hit the long portion of wrench and this should take care of your problem. Replace in the opposite if disassembly. Let me know if you need more help
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
