Cool for me, thank you
Please see here for some Technogym spares:
http://www.partsfortreadmill.com/catalogsearch/result/?q=xt++technogym
and here for dismantling your treadmill and changing the belt:
http://www.treadmillsrepair.co.uk/2013/12/belt-for-treadmill-replacement-and.html
USE THE PATIENCE, CAREFULLY, AND BASICS TOOLS.
Watch this Video:
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
Friction is the #1 cause of this problem. Many cheaper treadmills have amotor with a cardboard core (people wonder why we are so
down on cheap treadmills) and if the voltage and amperage through themotor heats it up sufficiently, it begins to smolder. If this is the
case, you normally have to replace the belt and the motor and inspectthe deck. If the armature has cooked enough in the motor, you
also have to replace the motor.
If the belt and deck check out OK, check for a short in the motor. Youcan run the motor with an independent power source like a fullycharged
cordless drill battery to see if the symptoms are the same. Click on thefollowing link for our motor test.
If the belt and deck check out and the motor is OK, then check yourwiring and electronics for signs of scorching and replace the
appropriate part(s).
Sincerely. God bless you.
If you need further assistance, please reach me.
If you are in need of buying a treadmill to be able to exercise. Please visit our address below. Because we rely on the needs of our customers to review and choose the best machines to recommend to you.
treadmill
