SOURCE: Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
My daughter's phone got slept on. Lens was not square and would not retract. After reading all the stories of woe I suspected it was alost cause. I pushed on the bigger piece of the lens till it clicked and it immediately closed up and worked no problem. If you still have warrantee let Kodak look after it, if not then brute force did work. Just push up in the direction it looks like it needs to go.
SOURCE: lens problems
there is a problem wit your lens section, get it repaired with your company professionals. Your camera may be fallen or being pressed from front side by someone. The new ZOOM will give the same best result and no further problems.
SOURCE: Self Repair Cracked LCD
I just replaced the LCD in my Kodak EasyShare753. I removed all of the screws that I could find, but still couldn't get the case apart. I finally found that the selector knob on the top of the camera has to be rotated to the SCN position. The lower part of the knob is slotted so that the camera case easily slides apart once the slot is pointing in the right direction.
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
