Hi
your pressure switch is bad. so it isnt cutting off the compressor. the part number is N003306SV and can be obtained from Dewalt on Servicenet.
Detail
Good luck and hope this helps
SOURCE: How do I adjust the cut-out pressure on my DeWalt
I had the same problem. The relief valve loosened up after a couple years of use. Right around the center pin in the relief valve is a ring that has a slot in it that you can fit a small straight blade screwdriver into and tighten in a clockwise direction. This should tighten the spring on the relief valve and raise the pop-off pressure above the 150 psi setting of the cutout switch.
SOURCE: Hi I have a Dewalt d55141 emglo contiues to run
wrong, no black box or cutout switch. p/o N003307
