Dell Latitude D620 Notebook Logo
Anonymous Posted on Oct 26, 2011
How to resetdell latituded 420 password - Dell Latitude D620 Notebook
Anonymous
Level 3:
  • Master 408 Answers
  • Posted on Nov 08, 2011
Anonymous
Master
Level 3:
Answers
408
Questions
Helped
90498
Points
1171
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
How to replace battery
Richard Barclay,
You can click the link below to view the online service manual for the Latitude 420. The manual will provide information for removing/replacing parts within your Laptop
http://dell.to/1L6aZCU
Thank You,
Dell-Jesse L
Dell Social Media and Communities
2answers
I do not have the username and password for my new Dell latitude 2120
There are 3 ways for you to reset Dell Latitude password. Let's specify them in 3 parts.
Part 1: Using a Password Reset Disk
When you create Windows user accounts for your Dell Latitude, you can also create a password reset disk at the same time with a USB flash drive or a floppy disk to reset forgotten password afterwards, which means you have to make this tool before you forgot Dell Latitude password. Meanwhile, this password reset disk can reset only local user account password. If you want to unlock dell latitude without password or disk, or your Dell Latitude is on a domain, please refer to Part 3.
Part 2: Reinstalling Windows System
If you have no password reset disk, Dell Latitude will suggest you to reinstall Windows system when you forgot password. However, the cost of reinstallation is huge because all your settings and data in C drive will be lost. If you don't want to lose resources on your Dell Latitude laptop, try the following method.
Part 3: Using Dell Latitude Password Reset (Reset Password without Disk)
If you want to unlock Dell Latitude (d620) without password or disk, Windows Password Recovery (Windows Password Recovery Tool) will be your best choice to access Windows 8.1/8/7/Vista/XP adminitrator in dell . It is specially designed to reset any local or domain account password without system reinstallation when you forgot password and can't log into Windows OS on Dell Latitude laptop. Here is the example of Dell Latitude admin (administrator) password reset. What you need is just a USB flash drive or a blank CD/DVD and an available computer.
Note: The steps to reset other user account password (no matter whether it is a local or a domain one) are the same.
  • Step 1: Download and install Dell Latitude Password Reset on the available computer.
  • Step 2: Insert a USB flash drive or a blank CD/DVD on the computer, specify the burning device, and click "Burn".
  • Step 3: Click "Yes" and "OK" button in the pop-up windows.
  • Step 4: Insert the newly created USB flash drive or CD/DVD on your Dell Latitude and reboot it. Select the Windows installation you want to reset the password, choose "Reset your password" and click "Next".
  • Step 5: Select the administrator account, choose "Remove the password" and click "Next". In the pop-up window, click "Reboot".
Dell 420 instructions
Need more info, Norman.
1) User Guide, or Service Manual?
2) Laptop? Dell 420? Would that be the Dell Latitude D420?
Going with Dell Latitude D420;
http://support.dell.com/support/edocs/systems/latd420/en/index.htm
User Manual = User's Guide
Click on the blue - View - to the right of User's Guide
Service Manual:
Click on the blue - View - to the right of Service Manual
Not the correct computer? Then look for the white Service Tag,
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&docid=267748&doclang=en&l=en&s=dhs
Need the letter/number under the bar code.
(DO NOT post the Windows product key )
Post back in a Comment.
Regards,
joecoolvette
1helpful
3answers
I brought a bizhub 420, how do i reset password
I had an older Minolta a couple of years ago. I'll try adapting what worked for it to this machine. Hopefully this will work.
Press the "utility" button. Then hit "admin settings". Enter a password of 12345678. Then hit "user authentication" and put in "off". Hit panel reset from the main menu.
Again, I'm not entirely sure this will work for the 420 but its worth a shot. Good luck!
1helpful
2answers
Reset voicemail password
Just enter 0000 fron the phone.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
