SOURCE: Sharp AL-1641CS Lase Copier
Hi, red cylinder means the drum needs to be replaced, i wouldn't bother if it is not causing any issues. to cancel the light; cancel, exposure, cancel, exposure, 24, print, 07 print, cancel cancel, jobs a good 'un, 'appy days.
Andy
SOURCE: We have a Sharp AL-1641CS Copier and it does not
this a problem with the scanning section the lense motor is not moving is stock or broken check for opstraction if not the lense motor is broken
SOURCE: Reset the copier counter AL-1641CS
c photo c photo then screen is blank press 14
press print key then show 00 is ok
SOURCE: We have a Sharp 1641CS copier will not feed or copy
The dropping of the toner/developer can be due to either a full waste bottle located at the front of the toner cartridge or from a short on the main charge corona. If a lot has dropped then the feed tires can get dirty from this toner spilling. You can check the toner cartridge issue but the corona should be checked by a technician.
SOURCE: I have a Sharp AL-1641CS printer/copier don't have
You should be able to use the driver at
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=Software&category=HomeOfficePrintersFaxMachines&model=AL-1641CS &
