SOURCE: I have accidentally blocked a
Settings > Applications > Messages > General settings>Block Messages.
Delete the no you have blocked.
Testimonial: "A One!"
SOURCE: samsung wave gt-s8500. how do
Go to messages>settings>general settings>block messages>then delete any blocked numbers you accidentally blocked! hope this helps. :)
SOURCE: i have accidentally blocked a
Hi To unblock the accidentally blocked number you need to do the following Press the MENU key Select MESSAGING Scroll down the list and select SETTINGS Select TEXT MESSAGE Select BLOCK NUMBER Highlight the number you wish to unblock and select OPTIONS Select DELETE Select either DELETED SELECTED or DELETE ALL and press OK Briefly press on the ON/OFF button to return to the Main Screen
Testimonial: "Thanks very much, worked perfectly. "
SOURCE: i need the unfreeze code
I think you having the Doubt in Your Model,because you here specified different ,different models,Each model is differ from other so you need to unlock the three model,(yes Tocco,star,S5620 all are different )..Or unlock Only one phone,you can better check in user manual and conform the Model...if it one Phone means....anyway you can get the Unfreeze code for those Phones at here Simpleunlocking.com and Unfreeze it
SOURCE: looking for code to unlock samsung GT-S5260
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website. This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked. Hope this helps.
