Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
A
Anonymous Posted on Oct 25, 2011
Our toro Rake and Vac model # 51574 has been used three times. this fall when we turned it on, it ran for about a half hour and then stopped....never to start again! Please help.
Sam Son
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 31 Answers
  • Posted on Aug 03, 2016
Sam Son
Expert
Level 2:
New Friend:
Greenhorn:
Answers
31
Questions
Helped
6020
Points
185
Go and check your products
3 Related Answers
Anonymous
  • Posted on Nov 25, 2008
SOURCE: Toro Rake and Vac model #51573
I was able to find PDFs of manuals from the manufacturer directly at this site: https://homeownersolutions.toro.com
Just run a search based on your model. In this case, simply type in 51573 in their search box. You get access to an online interactive manual and also makes PDF available.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: #51574 Toro Rake&Vac--Lost manual
You should have another door that goes in front of the impeller (blade) which doesn't have a vacuum attachment. You should first detach the vacuum door from the bottom, put on the blower tube, and install the other door that came with the blower. Hope that helps.
Anonymous
  • Posted on Dec 14, 2009
SOURCE: I have a 51592 Rake and Vac Toro blower.
I had the same problem - then the motor went shortly afterwards. time to by a new one - frustrating because I've only had it for a couple of years.
My toro blower will start but sucton not blowing the leaves where is the switch located
Remove the vacuum part and install the protection grid over the intake propeller. This protects you from getting caught in the propeller and engages the safety switch witch allows you to use it as a blower.
Dec 18, 2014 • Toro Garden
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
1helpful
Blower does not turn on
Apr 03, 2014 • Toro Garden
Snow blower shorted out
1helpful
Motor was losing power and burning
2helpful
3answers
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
1helpful
2answers
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
2answers
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
