Seems like the motor is spinning freely but under power shorts out
Could you explain the problem a little more for me? Does it run OK on start up and when you go to cut you have the problem?
No not really the blade starts to runs slowly but only for about two seconds then the breaker trips. Would a short in the switch or reset button cause this?
Sounds more like the windings in the motor. I would check to see if there is something hung up in there.
Will do thank you I'll let you know what I find . ~E
OK, keep me posted!
Thanks for the tips it turned out to be a loose wire nut within the junction box on the side of the motor. When i pulled the cover and pulled the bunch out two one connection just fell apart. cleaned up and she fired right off.
