Dehumidifiers Logo
Robert Johnson Posted on Oct 25, 2011
Delonghi des 12 defumidifier stay's in pause mode, what could be the problem.
My delonghi dem 10 dehumidifier is working and collecting water but but the pause is continuously flashing why is this
The flashing pause light on your DeLonghi dehumidifier indicates that the unit is in a defrost cycle. During this time, the compressor shuts off and the fan continues to run in order to thaw any ice that may have formed on the coils. This process typically lasts for 10-15 minutes before the unit resumes normal operation.
If the pause light continues to flash even after the defrost cycle is complete, it may indicate a problem with the unit's sensor or control board. In this case, it is recommended to consult the user manual or contact a professional for assistance with troubleshooting and repairs.
1helpful
I have a delonghi des 14 dehumidifier. Usually it goes into pause mode for 3 mins when you first turn it on with the yellow light on and then starts dehumidifieing.It now stays in the pause mode forever...
Just fixed this problem with my DES14. Its a fault with the circuit board inside the machine and is very easy to fix, even for a novice. Here is how to do it:
1) Open up the machine by removing the screws in the case. (Make sure it is unplugged!)
2) Locate the circuit board on the side of the unit.
3) At this point you have two options. If you want a unit with full functionality you need to buy a replacement circuit board. I found one on MasterSpares (http://www.mastersparesonline.com/product/index/10147) It costs about 30 pounds. Simply remove the old board and replace it.
4) If you want a working unit for no extra cost (but without the functionality of the humidistat) then remove the rectangular white connector from the circuit board which has red,blue,white and yellow wires entering it. Add an extra wire between the central white wire and the red wire that is adjacent to the yellow. (see photo).
5) Re-assemble the unit. If you have opted for the free option the unit will work when you plug it in and switch it on but will no longer cut in and out with different humidities (or have the annoying warm up period). Thankfully the water overflow cut-out will still work.
Hope it works for you! Feel free to ask if you are confused!
2helpful
Bought a Delonghi dd50pc dehumifier last week for my basement and I have the hose going uphill and out a window but the pump always shuts off after 3-4 minutes, filling the tank instead. Now when I lay...
You really answered your own question. The pump in the dehumidifier only has so much water lift capacity. By trying to run it up and out, you have exceeded the maximum lift capacity. Using a floor drain or even a bathtub drain in the basement will probably work, as long as the hose is not to long.*
However, if you can use a floor drain, there's no need to use the pump function. You can use the continuous drain on the back of the unit. using the drain hose provided for that application.
*The 13 ft lift capacity noted in the Owner's Manual includes whatever length of hose you're using to get to the window. As there is some friction loss involved. But, they fail to point that out.
Hope this helps you and thanks for choosing FixYa.
Need an instruction manual for a BCO216 - do you know where I can get one please?
Finlay, for whatever reason, Delonghi does not post their dehumidifier's Owner's Manual on line. You will have to contact their Customer Support Dept (800) 322-3848 to get one. Either my email attachment or USPS.
Hope this helped you. Have a good day.
Need an Operation Manual for Delonghi DN125 Dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
I have the Delonghi DE500P and the lever that indicates the bucket is full will not stay down and therefore the bucket full light remains on and the fan will not start. when i use my finger to push this...
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
Delonghi pac 160 ( with air condition & dehumidifier modes) pINGU
i would like to know if the =unit turns off when it get to the tempature that you put it at
Thanks
I went back and rechecked. If the fan mode is selected, you can only set the fan at one of the three speeds. If you leave it in the fan mode, the dehumidifier will not come on.
Once the fan speed is selected, it will run at that speed in the dehumidifier mode. The fan will keep running, even when the dehumidifier (compressor) shuts down.
The only way to get it to turn off is to use the clock setting, which either selects how long it stands-by before starting , or how long it will run before going back to stand-by. DeLonghi calls it "stand-by," we would call it "off." DeLonghi calls unplugged "off."
I've never turned mine to stand-by, because it will never get my entire house down to 30% humidity (I have it where my air handler returns air to the basement). I live in the greater DC Metro area, where 75% humidity is considered extremely dry.
Apparently the normal mode of operation is fan on unless awaiting a clock start, or encountering a clock shut-down; either condition puts it into the "stand-by" mode.
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
