Code was showing something wrong with the pressure switch, so replaced switch and checked furnace for clogs and condensation and still code still blinking 3 times! help please!
Hi Kim,
A couple things to check:
1) OK, you've replaced the pressure switch - good stuff. But the neoprene hose running from the pressure switch to the inducer motor... does it have any tears or cracks? Is the hose fittings clogged on the inducer side? Clean/replace as necessary if so. You cannot have any leaks or restrictions in this hose.
2) Try disconnecting the inducer (spent fumes exhaust fan) motor and check this motor coil for continuity with a multimeter. If the motor coil is dead, you'll need to replace the inducer (about $120.00?).
3) Check during initial startup of a heating cycle that there actually is 120vac arriving at the inducer motor coming in from the control board. If not, your board may be at fault.
Hope this helps!
Papa Fixit
I have a Goodman 110 btu furnace and it will run about a day to a day and 1/2 and will not run with the Covers on..
