Sorry Jimmy, the Dell Latitude D610 Notebook PC uses Integrated Graphics.
There is no graphics card to upgrade.
Your Dell either came with a form of the Intel GMA graphics chipset , or the ATI Radeon Mobility X300 graphics chipset.
http://support.dell.com/support/edocs/systems/latd610/en/ug_en/specs.htm
Either/Or
The way Dell states it, (And also this is for a LOT of laptop manufacturers), is that you have either the option when purchasing, of having an Intel GMA chipset for graphics, or discrete graphics of the ATI Radeon Mobility X300, for graphics.
Discrete being the word that fools people. Makes them think it has a dedicated, removable graphics card, when in reality it is a graphics chipset soldered directly to the motherboard, and is not upgradeable.
Primer:
GPU
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
Essentially the 'graphics engine'.
A GPU can be installed directly on the motherboard, (Integrated Graphics), OR installed on a removable graphics adapter card. (Graphics Card is shortened for graphics adapter card)
Integrated Graphics borrows from the system resources. The Processor and Ram Memory.
This is why programs, for example games, that use a lot of graphics 'power', do not perform well on a computer with Integrated Graphics.
{Read - programs that use a lot of graphics power. Such as some of the newer games. Integrated graphics, depending on what graphics chipset it is, CAN run some games. Ones that are not very graphics intensive}
A dedicated graphics card has it's own processor, and graphics ram memory. Does not need to borrow from the system resources.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The graphics chipset in your Dell Latitude, is mounted to the motherboard with a BGA surface mount.
Ball Grid Array
http://en.wikipedia.org/wiki/Ball_grid_array
To explain the BGA surface mount;
Let's use the older Intel Pentium 4 processor that uses a Socket 478 processor socket.
The bottom of the processor has contact pins. (478 of 'em)
The processor socket has matching socket holes for the contact pins. (478 of 'em)
With the BGA surface mount there are no contact pins. In place of them are Solder Balls.
There is no socket, or socket holes on the motherboard.
There are Copper Pads.
The graphics chipset is set into place with the Solder Balls lining up on the motherboard's Copper Pads.
Then heat is applied at a specified temperature, and length of time.
The solder balls melt which solders the graphics chipset to the motherboard. (To the Copper Pads)
Removal and replacement is properly performed with a BGA Rework Machine.
Costly, and not something you'll find a local shop performing.
{The machine is costly, and the operator needs to be S-K-I-L-L-E-D. Cost of having a chipset replaced is Ouch!}
There are two ways you can upgrade your graphics.
1) If you have the motherboard model with a form of Intel GMA chipset attached, you can purchase the motherboard that has the ATI Radeon Mobility X300, and install it.
2) Purchase a laptop with better graphics.
{Not trying to be snide}
For additional questions please post in a Comment.
Regards,
joecoolvette
