TCL LCD TV L24D10F Channel locked; need password
TCL LCD TV L24D10F Channel locked and default password "0000" and "1234" does not work. Please help, thanks.
  • 1 more comment
  • Anonymous Mar 17, 2014
    TCL LCD TV Channel locked; Mod: No: T-LED32D10 Serial No: ELIT102914 C-093 (Please Solution)
  • Muhammad farhan Jun 04, 2019
    Tcl 4k 43inch reset
  • rinas mohammed
    rinas mohammed Jul 18, 2019
    Tcl lcd tv l24d10f lock ple solution
    New Friend:
How to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Posted on Jan 02, 2012
Saan ako pwdeng makabili ng peyesa nk t.v ko model l24d10f.ung malapit lang sa concepcion tarlac/
Posted on May 03, 2013
3 Suggested Answers
6ya staff
SOURCE:
John Sambell
  • 3 Answers
SOURCE: I have a TCL L42M61AZ
A firmware update from TCL will fix the problem. Call them and they will send out the firmware and a serial cable (required for update) for free.
I did the update yesterday and it fixed the problem (sound but no picture).
You will need a PC or laptop with a serial port (RS-232).
Posted on Feb 08, 2011
Testimonial: "Great to actually have some information as to how to solve the problem. The manufacturer should actually have this information on their website."
Anonymous
SOURCE: TCL LCD TV. No sound on one channel only.
I had the same problem... try toggling through the "SAP" (multilingual audio feeds) for the channel. Mine was somehow set on "audio 3 of 3" for that channel, but there were only 2 audio feeds.
Posted on Jul 20, 2009
I lost my manual for my TCL smart tv model L4OS49008 and want to restore factory settings dont know the password, can u help?
Most TCL TV's did not require a password to reset factory defaults. They do however have a parental control password, the factory default for this is 0000. Also the code 0812 could override any password customized by the end user. Sort of a super user password.
These work on a large number of TCL models, however they may not work on yours as I am not familiar with the exact model.
Jan 20, 2018 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
How do i fix TCL LCD TV model L24D10F with black horizontal line causing 3 division of image
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2016 | Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
My smasung gt s5610k phone is locked asking for password please help me??
Do you mean the security lock or network lock?If it is a security lock try default codes like 0000,1234 or contact your service provider.If it is a network lock then you can approach Unlock-zone.com and specify the country,locked network of Samsung GT S5610K(S5610). Based on the availability you can get the unlock code along with free instructions.
Mar 06, 2014 | Samsung Jet S8000 Cell Phone
21m62s password
Hi Johan, just try a factory-reset via tv menu.
By doing this you'll be able to select a new password.
Please just go for it...you'll see how easy it's to reset your tv.
Hoping to inform you correctly I remain,
Yours friendly.
All the best.
Blessings.
Gladmar.
Feb 24, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
I have a TCL L42M61AZ LCD TV. I find that the "Channel 9" programs in Adelaide, Australia, namely GEM, GO and Channel 9 DTV will not show a visual picture, only play audio. All other programs are...
Jan 26, 2011 | Televison & Video
Feb 24, 2009 | RCA L37WD12 37 in. LCD HDTV
How to take off child proof lock?
try 0000???
Parental Menu Options
1. Press the MENU and VOL+/VOL- button
2. Press CH+/CH- button to select PASSWORD .
3. Then input the password 0000. It will bring parental menu display on the
screen.
The "Default Password" preset by the manufacturer is
"0000" . If you want to change the preset password to your own password, just
choose any four digits that can be easily remembered and set. Once you set
password for a particular channel, that channel will be blocked.
to reset tv you might have to contact support at this link.
http://www.haier.com/servicesupport/index.asp
Apr 12, 2008 | Haier HLH15BB 15 in. LCD Television
Televison & Video Logo
4,318 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
