Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
    New Friend:
  • 7 Answers
Check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Posted on Oct 23, 2011
6ya staff
SOURCE:
Why does my haier dehumidifier leak on bottom
Are you emptying the pan regularly? A dehumidifier takes the moisture out of the air by condensing it into a catch pan usually located at the base of the unit.
Jun 16, 2014 | Whirlpool Gold AD70USS 70 Pint Per Day...
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
How do I install a hose so this humidifier drains automatically?
Look at the drain pan, it might have a garden hose connection that you might have to knock out, mine is not the same model but it may be similiar, and then run it to a floor drain or such. Good Luck
Jun 30, 2011 | Whirlpool AD50USS Dehumidifier
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
Our machine is collecting water but I have a drip coming from the bottom onto the floor? It is coming from the behind the collection area?
This could be from a couple things, first is that as units get a little older, the drains and pans start to clog because as your removing water from the air, your also removing dirt. Sometimes this dirt builds up on the bottom of the pan and over time, it clogs the drain. This will allow the pan to overflow and spill over on the side that has the lowest spot. One way to tell is to shim up the back about an 1/8th or an inch. If it leaks from the front now, your drain is clogged. If it drains fine and the drip in the back goes away, you have corrosion in your pan and you'll need to take it apart an clean it, aluminum tape it, and silicone it to get back to full operation.
Sep 28, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
My dehumifier is leaking. The collector pan is fine. I took the covers off and could not detect anything. It is pretty simple...air blows by the coils, condenses, collects and runs into the pan. Looks...
TRY IT ON LOW FAN SPEED AND SEE IF IT LEAKS , MAKE SURE IF THERE IS A HOSE OR SMALL DRAIN PAN UNDER COIL   THAT IT IS CLEAN AND FREE OF DIRT .SOMETIMES ON HIGH WATER IS BLOWN PAST DRAIN PAN AND DRIPS ON FLOOR , THIS MAY BE A BAD DESIGN. IF THERE IS A FILTER CLEAN IT
Apr 20, 2010 | Maytag M7DH45B2A Dehumidifier
My Whirlpool Gold dehumidifier is making the circuit breaker switch off. I used the sweeper to clean all of the dust from the vents but it continues to make the breaker switch off.
Take the unit outside and wash the coil out with a garden hose. Careful not to get water on the controls. Water will not hurt the motor or compressor as long as you keep it unplugged. Allow the unit to completely dry before running it again.
Oct 04, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Our Whirlpool gold dehumidifier is leaking water. We have checked the water reservoir and it is in correctly and continues to collect water. But, water is seaping onto our floor from the dehumidifier.
Do you use a hose with your dehumidifier? Could it be leaking? I have two machines in my basement. I use hoses on both. I had to do funny stuff to make the hoses not leak on the plastic 'blown' tanks. Even the cap that originally came with the machines were leaking before I started to use the hoses.
Check for holes in the tank as well.
Sep 27, 2009 | Dehumidifiers
Dehumidifier leaking onto floor.
You should clean off the condensor coils with a vaccum and soft brush. Also, check up inside the area where the condensate drips into the collection reservoir (or goes directly into a hose attachment discharge) to see if something is partially obstructing the water flow and is dripping onto the floor, etc.
You might find that you've got some buildup of dust, dirt, and some other gunk that is mis-directing the water (condesate) that the dehumidifier is drawing out of the air.
Lastly, check the unit to see if it's level, but frankly, I highly doubt that's the issue, based on the 5+ years of good working service for you.
So long as the unit is still running and keeping the humidity in check, (if the above steps don't resolve the issue), I'd continue using it until it finally quits running, but I'd put a plastic boot/shoe mat under it to catch the small puddles of water.
The dehumidifier should draw the small puddles, so it'd be less expensive to get a $4 boot mat than dropping another $240+ for a new unit, as your's seems to be working fine, aside from the occaissional puddle issue.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Dehumidifiers
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
1,957 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Perry Mellott
Perry Mellott
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
