for Aircel PUK code u have to contact with your service provider ..talk with customer care and ask for the PUK code ..just in case your number is blocked so u can use any other number of same service provider.
How to find PUK code for Aircel sim card
It is very easy to get the PUK, all you have to do is just call Aircel Customer care through your another Aircel number or from your friend mobile who are using Aircel.
Before calling customer care make sure you have
1.The 8 -15 unique number printed on your sim card, Incase if you dont have it on your simcard you may find it in the cover pack which comes with new sim card.
2.The name of the owner of the sim, owner means the name which you have given when you are buying the new sim.
3.There are some rare cases where they ask about the last recharge amount or date.
switch off your phone then take out your sim card. see the sim card there is a set of numbers are printed .note down this numbers then place your sim and switch on your mobile. Now take another mobile with the same aircel network . call the customer care from that mobile and ask them you need puk code for your number . They ask sim and phone number .say your phone number of the sim which is puk code locked and the sim card number which is printed on your sim card. they will say a puk code no and a pin code number .Note down this numbers and type it on your phone .Now your sim will be unlocked
You need to call AIRCEL.
Only they can give you your PUK code.
You will need your IMEI number from your phone. It will be under the battery or if you can...Type. *#06# into the phone and this should tell you your IMEI number.
u need to call up the customer care from another number in aircel network and tell them u(or what do u maintain relatives for?) accidentally locked ur sim with the phone... and that it is requesting for ur puk code... this wouldnt be a problem if it is a sim in ur name
The PUK (pin unlock key) code is usually printed on the Back of the SIM pack check it out and if it isn't there then u need to call your carrier and they will give to to you after verification. Make sure not to enter the PUK code your self after 10 incorrect attempts the Sim will be permanently blocked and then u'll need to get a new one! For More Details Please Visit The Site http://www.keywordarticles.org
Just dial 111 using other aircel mobile to contact customer support. The PUK code must be given by the network support in able to unblock again the SIM, please do not enter more than trice of the PUK code or do not eventually guess the code it will permanently block the SIM and you will able to use it again.
By the way what exactly the location or country you are located in, so if there no other aircel mobile available to contact directly the Operator, i'll try to look their trunk line number where you can also contact with them.
