Microwave Ovens Logo
Anonymous Posted on Oct 22, 2011
I have a 6 year old GE overstove Spacemaker XL 1800 microwave. Every function works fine on the electronic panel except it does not heat anything up. I have the schematic and flow chart from inside and a multimeter. I think it is the magnetron, but I want to eliminate everything else. Gene
Anonymous
Level 3:
Guru:
  • Master 586 Answers
  • Posted on Oct 28, 2011
Anonymous
Master
Level 3:
Guru:
Answers
586
Questions
0
Helped
211774
Points
1670
Hello there,
You are right that the problem is from the magnetron, it is defective and need to be tested and replaced. Since you have a multitester, you will be needing a ohm meter, here are the steps to testing and replacing the magnetron.
To test the magnetron, please follow these steps,
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitors.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
To replace the magnetron
Have a certified and experienced appliance repair technician examine and replace your magnetron. This task is much too dangerous for the average layman to perform on his own
Hope this was helpful you.
All the best
Elect_Comp
2helpful
2answers
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
1helpful
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
GE Spacemaker XL 1800 making odd noise when on and not heating anything
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
My GE Adora Spacemaker XL 1800 is no longer heating the food. What do I need to do to replace the microwave emitting bulb?
may be , the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. it need to be replaced .
No heat coming from Microwave oven-GE Spacemaker Model XL 1800
in the microwave there is a part which produses the heat which will be called as magnetron you check that part.
2helpful
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
1helpful
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
5helpful
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
