Sony Ericsson Akono HBH-608 Wireless Headset Logo
Posted on Sep 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Passkey for HBH608
My HBH 608 bluetooth seems to have gotten into the pairing mode, but I can't find the passkey. Can anyone help where I can get one from? Thanks
Anonymous
Level 3:
  • Master 405 Answers
  • Posted on Feb 19, 2009
Anonymous
Master
Level 3:
Answers
405
Questions
Helped
261346
Points
1263
I have a Sony Ericsson Akono Headset HBH-608. I have a Blackberry Torch, and this headset works perfectly with the Torch. I just bought a Motorola Atrix, and I can't get it to pair up with my headset. I've...
Below is a link to the PDF Manual.
Its a little confusing but it would appear from Pages 13/14 you need to press the call handling button for 5 Seconds until the indicator light flashes Red/Green. Although it doesn't explain it very well I believe this is then in Pairing Mode and your phone should now find it and enable you to enter the passkey.
http://dl.owneriq.net/a/abb99094-bd23-4b22-a914-03aa43fc51dd.pdf
Please leave feedback
Cheers
Andy
3helpful
Pair my Sony Ericsson bluetooth HBH-PV703 with Pantech Impact cell phone
You must put your headset in pairing mode first. Starting with it turned off, press and hold the call handling key until the indicator light flashes alternately in red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode, and there should be some indications on your phone too.
The pairing process between any two bluetooth enabled devices should be done only once. All subsequent connections should be achieved by turning both your headset and your phone's bluetooth radio on and bringing them both into each other's range. At most, a single press on the headset's call handling key should do.
Hope it works for you.
By the way, if your headset's user guide seems to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
2helpful
N97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
11helpful
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
1helpful
I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
5helpful
2answers
Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
1helpful
P990i is not supporting headset bluetooth HBH-PV700
You must operate your bluetooth headset HBH-PV700 in discovery mode in order for your mobile to discover the headset and then pair the two devices. To activate the discovery mode of your headset, while it is switched OFF press the switch on button and leave it pressed for approximately 10 seconds, then search for it with your mobile and pair the devices. most of the times the code needed for pairing is 0000 (zeros)
Sony HBH608 Bluetooth Headset
If it is for ps3 got to home page then turn the controller off manually then turn it back on and it should work
2answers
Bluetooth ear piece
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
6helpful
2answers
UNABLE TO PAIR MY BLUETOOTH
Try to hold the volume command on - and + both It will recognize the device when searching for bluetooth headset.
Top Sony Ericsson Radio Communications Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
