Hi, Just got your request and am now going to look up all I can find on this model of tractor. In the mean time double check your push or drive lever again to make sure it is not binding and make sure the blades are not selected, although I am sure they are not but at this point I am not ruling anything out. I will have to dig into this issue and check on the trans axle set up for you.
I seem to be having trouble posting a reply, lets see if this goes through
I can't seem to paste my notes I have written on this. So I will do this again. Basically the things that can cause this are the filter and fluid, since the fluid is full and I assume clean, then I would suggest a new filter to make sure the pressures are correct to move the tractor. I would also like you to make sure the idler spring tension good and that the spring on the idler pully is not broken. If all seems good and after changing the filter it still will not move , then I would suspect a broken drive pin in the pump. These shear off occasianally and the pump needs removed to be rebuilt. the wheels are turning like they should so I hope to rule out an issue with the gears. As far as repair cost, that varies from dealer to dealer but I would expect a charge between $100.00 and $200.00 for parts and labor on the pump rebuild. A new transaxle runs around $500.00 before labor costs
Do you know who the manufacture for the trans axle is. There should be a plate on the trans asxle that tells the manufacture, I assume it is Hydro Gearr but I can't be certain
There is a shaft coming out of the trans axle with a big flat circular plate its frozen in place sand the rust off both sides.
