Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
A
Anonymous Posted on Oct 22, 2011
Epson printer tx 121 when i start the printer it could not be on power supply problem
Anonymous
Level 2:
New Friend:
  • Expert 123 Answers
  • Posted on Oct 26, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
123
Questions
0
Helped
36366
Points
158
Check if power supply heats up. if not, definitely its a power supply problem brother printer cartridges
1 Related Answer
Anonymous
  • 123 Answers
  • Posted on Nov 17, 2011
SOURCE: my Epson TX 121 Printer Wont power on
is it plugged it properly? what happened to the printer the last time it turned on?
dell printers
Epson stylus tx121
IF THE RED LIGHT IS ON EITHER IS INK OUT OR PAPER OUT
2helpful
2answers
My epson stylus tx121 printer has a no power on problem
Hello sir/mam, mera epson tx 121 chalte chalte achanak ruk gaya aur usme print bhi bahut slow se hota tha. Me kya karu usk lie. Pls.reply on my email: [email protected]
1helpful
My epson stylus tx 121 doesn't print..... it says ur printer s not ready... but everything s ryt at my end.... i need some solutions
First how are you connecting to the printer? Is it a direct USB connectionor are you using a USB hub or print server (sometimes part of a router)? If a USB hub is in use, is it a USB powered hub or a self-powered hub (AC adapter)? (Make sure that the printer has power and is turned on. Also make sure that you have printed and scanned a calibration )
If you are not using a direct connection, try a direct USB connection. Use a different USB cable and try different ports (some ports have lower power throughput than others). Make sure that you have the correct driver for your OS. (The full software is useful for other issues.) See http://www.epson.com.ph/epson_philippines/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_TX121 for the drivers.
Try uninstalling the current printer driver and then disconnect your data cable (USB). For Windows, press Start and open the Devices and Hardware control panel (Printers and Faxes in XP) from the right hand column. Right click on the printer and select Uninstall (or left click and choose Uninstall from the Menu bar). Reboot the computer and install the Epson printer driver before reconnecting the USB cable. (Otherwise you can get the OS driver that may not work as well.) Remove your data cable from both the computer and the printer and turn off both devices. Unplug the power cord from the printer and the wall outlet. Wait a few minutes before reconnecting the power. (This will reset most printers if there is an error in the printer itself.)
If you are using a print server and the direct connection worked, check the installation information for using the print server. Not all printers are compatible with certain print server drivers and you can have a conflict.
If a direct connection to any of your computer's USB ports does not work, check if other USB devices work. If not, try updating or uninstalling your USB controller (in the Device Manager for Windows - Start > Control Panel > System and Security > Device Manager, scroll down to the Univeral Serial Bus controllers). Then reboot your machine and see if the correct driver installs. Alternatively, check your computer manufacturer and see if there is an update for your USB driver.)
If the problems persist, you may have a bad USB port on the printer. Please add a comment with the type of connection between the computer and the printer.
I hope this helps.
Epson sylus tx121
tx 121 general error is about service of the printer contact your nearest service centre .
u can also chek you cap assemble(where printhead stop in off position) the lock of cap assembly manualy move can sole your problem
4helpful
2answers
My Epson TX 121 Printer Wont power on
dell printers
My epson tx 121 printout has a roller lining after it finish printing. how can i avoid it.
What probably would work the best is to take some alcohol to the roller and try to clear as much gunk as you can off of it. Might fix the problem for you.
72helpful
3answers
3helpful
3answers
Using epson stylus tx 121, how to scan my picture so it be stored in my computer?
You need to install Epson Twain Driver, go to this link to download:
http://download.cnet.com/Epson-TWAIN-Scanner-Driver/3000-2118_4-10007006.html
Good luck
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
