Question about Weiser Lock Powerbolt 1000 Lock
When I punch the code to unlock the keyless entry there is a steady beeping
  • 963 Answers
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Navigate to the complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Then go to: US & International/FAQ Categories/Keyless Entry/Powerbolt 1000/Search Results/ How do I troubleshoot my Powerbolt 1000?
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Good luck--and please provide feedback if this helps!
Posted on Oct 31, 2011
  • 31 Answers
The beeping means that you have entered the wrong code.
Posted on Oct 24, 2011
6ya staff
SOURCE:
Why isn't keyless entry working?
Remove the battery and have it replaced.
Feb 20, 2016 | 2011 Volkswagen Tiguan
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I don't have a manual for my 2004 lincoln Avaitor but would like to know how I can change the code on the drives door key pad
KEYLESS ENTRY SYSTEM With the keyless entry keypad, you can: • lock or unlock the vehicle doors without using the key. Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located: • on the owner's wallet card in the glove compartment • or at your dealer. When pressing the controls on the keyless entry keypad, press the middle of the controls to ensure a good activation. This system will disable the power door lock controls. These will not work until the vehicle is disarmed. Programming your own personal entry code To program your own code: 5. Enter factory set code (keypad will illuminate when pressed). 6. Press 1/2 control within five seconds of step 1. 7. Enter your personal 5 digit code. Enter each digit within five seconds of previous one. 8. After the code is entered, the locks will cycle, confirming that the new code has been set. Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes. Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase the first personal code in favor of the new code. Locks and Security 149 Locks and Security If you wish to erase your personal code, use the following instructions: 1. Enter factory set code. 2. Press 1/2 control and release. The system will now only respond to the factory set code. Anti-scan feature The anti-scan feature prevents repeated attempts at arriving at a valid key code. The keyless entry pad is disabled for 1 minute after 7 unsuccessful attempts (35 consecutive button presses) at entering a valid key code. The keypad will flash during this 1 minute mode. However, the 7/8 and 9/0 controls will still lock the vehicle. Anti-scan will be turned off after: • one minute of keypad inactivity. • the remote entry transmitter UNLOCK button is pressed. • the ignition is turned to the ON position. Unlocking the doors with the keyless entry system To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will also illuminate. To unlock all doors, enter the factory set code or personal code (driver door unlocks) and press the 3/4 control within five seconds. Locking the doors with the keyless entry system It is not necessary to enter the factory or personal code prior to locking all doors. To lock the doors: • with the driver's door closed, press the 7/8 control and the 9/0 control at the same time.
Dec 17, 2009 | 2004 Lincoln Aviator
How do i reprogram keyless entry codes
door pad keyless codes?
in owner manual, enter permanent code and then press "1" and enter personal code, then press "1" again. Then both codes will work.
If you don't have manual, go to Motorcraft.com and click on technical resources and click on your year owner manual.
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within five seconds of the previous button press.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad will flash during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after any of the following events:
  • the keyless entry remote transmitter UNLOCK button is pressed
Unlocking the Doors with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Dec 01, 2009 | 2004 Ford F350
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry keypad
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Mar 08, 2009 | 2003 Ford Taurus
Reprogram keyless entry system
1991-94 Nissan Maxima key less entry reprogramming procedure:
1. Enter the *original code found under the dashboard.
(*the code begins with the letter F and has 7 digits)
2. Close the doors and lock all of the doors,
enter the 7 digit code ( make sure you have your key in hand).
3. Once the code is entered correctly you will hear a long beep ♪ ♫.
While the beep ♪ ♫ is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps ♪ ♫)
Do not touch anything until the beeping ♪ ♫ stops.
4. To open the doors, the front windows and the trunk,
type: S(Clear) and the New 4 digit code and the door will open automatically.
5. IF by any chance you forget your new code. Just enter the original one and start all over.
Oct 23, 2008 | 1994 Nissan Maxima
Keyless entry
I believe dealer has to re-program the new code.
Aug 29, 2008 | 2001 Ford Explorer Sport Trac
Weiser Lock Powerbolt 1000 Lock Logo
106 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Azam Ali
Level 1 Expert
Scoee Scoffer
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
