Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Anonymous Posted on Oct 21, 2011
Shark SV736R motorized brush won't rotate
The cordless Shark 15.6v works and picks up dirt but the motorized brush won't turn. I have removed all lint but can't find a tool to take out the screws (not normal phillips head or flat). Maybe there is hair wrapped around the roller. I managed to get some out with a thin blade but the brush still won't turn. I really need the brush for carpeted stairs and hate to buy a new hand held just because one attachment won't work.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 360 Answers
  • Posted on Oct 22, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
360
Questions
Helped
90818
Points
925
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
  • Anonymous Oct 22, 2011
    Yes, I first read the manual, and did both the things you mentioned. I just tried carefully inserting the brush again and looking for more lint, hair or debris that could be removed from the roller, but although the vac turns on and has suction the brush will not turn. I may have to trash this. Thanks for trying to help. I hoped there was something else I could do that was not in the manual.
Brush not rotating on my shark rocket cordless
Be sure the brush roller switch is turned on. Also the handle must be pulled back in order brushes to turn.
tip
Cordless Shark Vacuum Brush Bar Stops Working
My cordless Shark Vacuum brush bar would stop working each time after a few minutes of use. I was getting ready to throw the vacuum cleaner away, but decided to pull the bottom cover and check it first. I did the following modification and now it works great!
Just a few notes before attempting this tip: You need to be carefulafter this modification if you see the brush bar stop as this couldmean the bar is really jammed and there is a risk of the brush barmotor burning out. Most of the time disabling any fuse or circuit breaker is a very bad idea and could ruin equipment and even cause a fire. In the case of this tip, only consider the modification if you areready to get rid of the Shark because of the brush bar problem. Another option is to replace the circuit breaker, however consideringthe time and money involved vs. the cost of the vacuum cleaner it mayor may not be worth it to you. I did this modification to my cordlessShark about 4 months ago, and have had no further problems with it. I takes about 15 minutes to do this modification using a screw driver and wire cutters.
1. With the vacuum cleaner off, check the brush bar by manually rotating is with you hand. It should not be jammed or very difficult to turn. If so, remove the brush bar and clean it. Try the vacuum again. If you still have a problem with the brush bar stopping, proceed to next step.
2. Remove bottom cover around brush bar / motor.
3. There are two wires going to the brush bar motor, one wire includes a small circuit breaker.
4. Clip the circuit breaker out of the wire and reconnect the wire straight to the motor.
5. Re-install bottom cover.
on Apr 25, 2010 • Vacuums
My brush on my rotator shark vac. will not turn I checked the belt it's fine
Try turning brush by hand and if it's stuck then it needs to be worked on. Could be bad bearings or jammed with dirt .Even carpet strings will stop it. If it turns by hand your belt could be stretched.
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Shark rotator no suction
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+rotator
Ava B.
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
1helpful
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 • Vacuums
8helpful
Shark cordless 15,6v need to buy ac adapter Ktec KA12D220020034U
need a Ktec ac adapter listed above. KA12D220020034U. HOW MUCH FOR THE ADAPTOR AND HOW SOON CAN I GET IT.
Aug 30, 2009 • Vacuums
My vacuum (shark modle #UV210BV) turns on but has absolutely no suction.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
