Question about Proform 730 Folding Treadmill Model PFTL71104 - !
How do i fix an e2 error and get a wiring diagram
Key in set program(manual) motor and belt run and move for 5 sec. then shows e2 error
    New Friend:
  • 69 Answers
You can get new brushes here
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-motor-replacement/treadmill-motor-brushes-20x9x22-h-mm.html
and you can check here for treadmill help in general
http://www.treadmillsrepair.co.uk/
http://www.partsfortreadmill.com/repair/repair.htm
Posted on Dec 08, 2014
    Top Expert:
  • Proform Master
  • 12,223 Answers
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Posted on Oct 21, 2011
6ya staff
SOURCE:
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
Apr 23, 2012 | Exercise & Fitness
I have a Livestrong 13.0 Treadmill and have had some problems with it. I assembled the treadmill made sure the connections were right and the belt would never start up. After 10 sec I got an E1 message...
Dear Sir:
You need to RUN YOUR SOFTWARE CALIBRATION, most of them is coming the instruction below from Hood of motor, follow the step, or use your instr.manual.This is for easy diagnose and troubleshooting.
2) Adjust the sensor speed +tight the wires, see the diagram below.
3) You must Test the main motor for Open+Short Winding.
4)Test the transformer for primary and secondary voltages.
5) See if in power supply you get +5vdc, for digital circuit.
6)Lubricate the deck vs walk belt.
Attached my block diagram for easy diagnose in treadmills
sincerely.God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 16, 2012 | Exercise & Fitness
Error 2 in Goldstar MTD 602 treadmill
1) Adjust the speed sensor 2) Tight very well the connection from speed sensor. 3) Faulty Sensor speed 4) Faulty Main Motor measure for 115 VAC without load. 5) Main motor board faulty , test for 115 VAC,and oupput for +5Vdc. 6) See the transformer for 115 VAC,for primary voltage and secondary voltage. 7) See if some component such: resistors, capacitor, diode, or IC burn. 8) Lubricate the deck belt. 9) Adjust the tension for deck belt for lift 2-3" max. 10)error code e1 vs e2 in some mark is equal is different from some manufacturer.
See the block diagram for your diagnostic, for strong resultant.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua.
Dec 18, 2011 | Exercise & Fitness
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Optic Sensor
Motor
motor brushes.
Other
board, marked U5. .
continuity.
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
SINCERELY. GOD BLESS YOU.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 20, 2011 | Exercise & Fitness
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
545 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
