Timex T276B Clock Radio Logo
A
Anonymous Posted on Oct 21, 2011
How do I set alarm and clock - Timex T276B Clock Radio
Anonymous
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Oct 21, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
59
Questions
0
Helped
13082
Points
178
Normally there is a Time / H, M buttons, press the time and then the H, M buttons, if there is no time button, you need to press and hold each button H = Hour M = Minute
How to freeze the color on a timelink alarm clock
Freezing the color on a TimeLink alarm clock may not be a feature that is available on the device. Alarm clocks usually have a limited set of features and color freezing may not be one of them.
However, there are some things you can try to change the color of the alarm clock:
  1. Check the manual: The first step is to check the manual that came with the alarm clock. It may have instructions on how to change the color of the alarm clock's display or backlight.
  2. Check the settings: Some alarm clocks have settings that allow you to change the color of the display or backlight. Check the settings on the alarm clock to see if there is an option to change the color.
  3. Check for add-ons: Some alarm clocks have add-ons that allow you to change the color of the display or backlight. You can check online or in-store for add-ons that are compatible with your alarm clock.
It's important to note that freezing the color on an alarm clock may not be a feature that is available and that the alarm clock's color display may be fixed. It's also important to note that attempting to change the color of an alarm clock may void the warranty, so it's best to check with the manufacturer before attempting to do so.
If you're not able to change the color of the alarm clock, you may need to consider getting a different alarm clock that has this feature or look for a workaround such as using a different light source or a different place to put your alarm clock.if i was able to help my cashapp $ralphpapi thank you have a blessing day
Need instructions setting sharp alarm clock SPC293
hi cheryl.
this is all i could find,if this does not work go to the link and the bottom.
How to set time on sharp alarm clock? Change switch to BUZZER. 3.) Press and hold the ALARM button on top of the clock. 4.) Press HOUR button until desired hour is displayed.12 Feb 2013
Sharp Alarm Clock Inustructions by Matt Boysen on Prezi
https://prezi.com/vgxxmjfbc1ya/sharp-alarm-clock-inustructions/ Search for: How to set time on sharp alarm clock?
instructions setting sharp alarm clock SPC293 Google Search
1helpful
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
1helpful
2answers
How to set alarm
Hi Margaret
It's ultra simple
Home Page
Click "Clock"
Click bottom "Alarm"
best alarm clock app for iphone YouTube
Joy Factory Prism for iPhone YouTube
Mar 14, 2016 • Cell Phones
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 • Home
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
6helpful
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
3helpful
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Alarm
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
Top Timex Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
