My craftsman garage door remotes have stopped working on one door. I've changed the batteries, bought new ones, reset the remotes, made sure the side wasn't locked and still noting. Frustrating! The lights work, the wall unit works but neither remote will open that side? Any help would be greatly appreciated.
As Ray stated change your battery and clean the contacts and the button with some alcohol. Check and make sure it works with your wall switch. Lastly the receiver in the opener could be going bad.
You will need to purchase a new remote with the same model number as your old ones. When you get this you will find that you can program the new one with one of the old ones but not the other. Remove the battery from the bad remote and discard it.
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
