SOURCE: Operating system not found, hard disk not found message showing in IBMT20
Your hard drive is most likely bad or the ribbon cable is not connected.
SOURCE: Toshiba Satellite PC ... Operating System not found
Enter the laptop's BIOS and switch the boot device.
Make sure its a local drive (C) and make sure LAN boot is OFF.
Let me know if it worked out.
If the problem persists you might have to flash your BIOS
SOURCE: DRIVERS
Found someone with the same problem he solved it and posted the page here
http://www.xaqdesign.com/c762nr.html
Just follow the guide and you will be good to go
Hope that helps
Let me know if it solves your issue or if you need more help
Scanss2k
SOURCE: hp compaq cq 40 108 tu laptop can i get audio video drive
can i get solution to install win xp on compaq cq 40-108
SOURCE: My Presario C771TU Laptop for Windows XP Sound
try to install the driver by updating the driver in DEVICE MANAGER
your driver are located on C:\swsetup
