The phone is probably overheating charging puts out alot of heat is these little phones, if your using i while it charges that could also be a reason its over heating as well and its not in a well ventilated area such and a bed or something that wont let the back of the phone where the battery is breathe which will cause it to over heat
Hi, there is your mobile dialing fault there may be inner keypad is demages. so if you can chang it, pl chang and check it. For ur second problem is phone not go on when fully discharges, at this time you have to put your mobile under charging for three or four hour, dont worry when u put mobile in charging mobile will not shows charging but there is a charging is on in mobile after one hour mobile will shows charging automatically. ok. test this and pl.reply earliest.
