SOURCE: my GE double oven is flashing F1 and beeping
The F1 error is similar to the F7 error and the fix may be similar. It indicates that the touchpanel needs to be replaced. The problem is really one where the insulation is breaking down between two sections of the ribbon cable which connects the touchpanel to the electronic control. I have solved the problem by placing slip of paper between the two secions of the ribbon cable. The slip of paper should be worked down into the slot. It will only go about 1/8". A piece of file card material works well. See attachec photo. If you have a metal touchpanel, you will also have to add slips of paper at the edges of the metal slot. __Be sure and turn off the power to the oven at your circuit breaker!____There are usually three small screws at the bottom of the touchpanel. The panel may need to be pushed upward to release it. Have a friend available to hold the panel while you work on it. Do not allow the panel to dangle by the wires.____Please let me know if this works for you or if you have any questions. You can reach me at [email protected]. I have shared this solution with over 830 folks. Most report success.
SOURCE: GE Profile Performance Double Oven
I had a similar problem, try the fix belowhttp://www.fixya.com/howto/h155060-dreaded_f7_error it may work.
SOURCE: GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
shorted touch pad(memberant)becareful remove ribbon cable clean and reseat you can test the touch pad alot of the touch pad failed because the heat(poor design cheap make)
SOURCE: GE Profile Oven/Range Constantly displaying -F1- Error code.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%^&ytg
Hi
F1 Error indicates a bad control board and the control board
(electronic control) should be replaced to solve this issue. Hope this
helps...please post back for further assistance.
Daniel
