Sony DAV-DX255 System Logo
adnan Posted on Oct 19, 2011
DAV-DZ150K Sony Hometheatre, the tray does not open,when i press the open button it error display is disk error i dont understand what it problem tell me plz solution
tinotenda
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 08, 2019
tinotenda
Contributor
Level 1:
Answers
Questions
0
Helped
200
Points
Write your answer...childlock on my Sony DAV_dz150k how to fix it
5 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Apr 01, 2008
SOURCE: Change of region code from 1 to 0 in Sony DAV-HDX265
http://www.multiregionupgrades.com/
A
Anonymous
  • Posted on Jul 18, 2008
SOURCE: Sony BRAVIA DAV-HDX265 Changing the region code
hjk.j
Anonymous
  • 18 Answers
  • Posted on Dec 30, 2008
SOURCE: Sony DAV-SB100 - Tray won't open
the only way to get it open is threw the inside of the system and i wouldn't advise you to do that unless you know something about electronics or if you are lucky try to unplug it for about 30 mins and see if it will reset itself and plug it back up, and when you plug it back up only press the eject button. good luck!!!!!
tc3gs400
tc3gs400
  • 14 Answers
  • Posted on Jan 12, 2010
SOURCE: how to play multi region disc in sony hometheatre dav-dz280
your player comes as a multi reader player..
Dennis McCollum
  • 137 Answers
  • Posted on Apr 16, 2010
SOURCE: The DAV-S300 tray does not open when the eject
There is a transistor on the bottom of the main pcb assy which shorts out causing no voltage to the open/close motor. This is a common problem with this model.You may able to see this transistor as it will look burnt.it is a smd transistor
2answers
I have a Sony DAVDZ150K home theater system. It displays DEST error. What is remedy please.
Not sure. General advice is 1) Try cold start (unplug, let set for several minutes, replug and try) 2) Try a reset (page 72 of user manual) 3) check any cabling. The troubleshooting in the user manual does not refer to this specific error.
https://www.manualslib.com/manual/948580/Sony-Dav-Dz150k.html?page=81#manual
My Sony dav-dz150k home theater is displaying push power protect.I checked the the sound output,the speaker wires for shorting but are fine
Hi.please check on your device control panel if you have power control key push it ,if not please see behind the device it may be there
Display shows "push power protection"-DVD home theater system
there is a short in the amp that needs to be repaired before the unit will operate correctly.
1helpful
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
The DAV-S300 tray does not open when the eject button is pressed. Please help! I have checked the manual and it says when locked is displayed on screen contact Sony but locked is not displayed on screen....
3helpful
1helpful
2answers
3helpful
Dav-DZ100
hehehe, its funny problem. let me try to help you.
1- Press Power to turn the set ON.
2- select DVD function.
3- press STOP and EJECT buttons for Five (5) Seconds.
4- the message UNLOCKED will display.
Enjoy n have nice day ;)
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
