Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
