SOURCE: TV just died...
Hi there!
The fuse may have blown. If so and you know how to check for a faulty fuse inside a TV, it may be worth a shot. Please unplug before opening and replace fuse with same value. If it blows again, you have to have it seen to by a repair technician. Good Luck, Regards, JUS004
SOURCE: Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
SOURCE: We've been experiencing problems with our Sony Triniton Wega TV
The 7 blinks usually mean a high voltage shutdown has occurred. This can be a simple repair or more involved. If you are comfortable working inside the set where there are potentially dangerous high voltages, and can solder, you can try and repair this yourself. Let me know if you wish to attempt this and I'll supply additional details and instructions.
Dan
SOURCE: Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
SOURCE: We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
When ever I turn on the TV it blinks 20 times slowly and then it starts blinking 5 and 5 and 5 quickly continuously.
