Error occurred after we lost power. All lights lit up on panel
Thermal fuse blown this guy says
Ricoh Error Code SC541 sc542 sc 543 sc544 sc545 sc546 Lanier Savin...
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
