Hp office jet pro k550 printer will not print the first line of a document and then will skip some lines only printing a small portion of the skipped lines
Printer contain 4 cartridges and 2 printeads. Because the black color skip some lines as you mentioned you need to replace a new printead(not the cartridge) No:88 Black/Yellow color one. For more information visit the following link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&docname=c00841890&product=2512009
When your printer seems to be skipping lines it's mostly because your printhead needs cleaning. This cleaning must be done ONLY by using the printer utility on the PC. If you cleaned them manually you might have damaged the ink cartridges or the printer itself. Try replacing the ink cartridges and trying again.
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc. Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
