SOURCE: configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
SOURCE: My Xbox 360 Nat is Strict. with my Belkin
again give it then save it then reboot it the router then try it
SOURCE: Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at [email protected] on add me i believe my ps3 thing is ADV_WARfighter
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
