SOURCE: need driver for sony vaio VGN-CR220E built in web cam, motion eye
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E
There u go, all availble files for Vaio VGN-CR220E and Vista
Good luck
SOURCE: motion eye camera for my vaio laptop is not
Is it the Driver you are reffering to ?
(In that case) Run Windows update and check under 'Optional Updates' for a possible Driver
SOURCE: Motion eye\ web cam not working on Vaio VGN CR11
http://esupport.sony.com/CA/perl/swu-download.pl?mdl=VGNNR460D&upd_id=3540&os_id=28
here is the driver for this unknown device!
njoy!!
SOURCE: Sony VAIO VGN-CR320E Motion eye camera never
Have a look in device manager
Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc
have a look under imaging systems click on the + sign and see if you have a Camera listed
Also on Sony they should have supplied an application for the camera
maybe called ArcSoft WebCam Companion - see if you have that program folder - listed at all
SOURCE: Driver motion eye camera sony vaio vgn ar31sr
Sony has not released the Windows 7 Driver for this Computer model. However, you can try installing the original Windows Vista Driver to resolve the issue.
Please download the Driver from the below link
Download the Driver
Please click the "Accept" button on the page to download the Driver.
Then, please unzip the file and double click on the "DPInst32.exe" file to begin the installation.
After installing the Driver, please restart the Computer for the settings to take the effect.
Camera should work correctly after installing this Driver.
However, you may need to download and install the Camera Application to use the Camera. You may also use the Camera with any messenger Application like Skype or Windows Live Messenger.
You can download the Windows 7 Compatible "ArcSoft WebCam Companion Software from the below link.
Download the Software
Please click on the "Download Now"option on the page.
Then, please double click on the file to begin the installation.
After that restart the Computer for the settings to take the effect.
Then, the Camera should work correctly with the WebCam Companion Software.
