so what makes you think the laptop has BT? its and option on all PC made, when new (check this first)
is this the only BT device you own? do tell. and can be added to any PC on earth with a BT USB dongle stick. for like $4 what is the distance to the speakers (BT uses radio signals weak) 10ft 50 ft (10 meters) what? distance matters on all transmitters regardless if BT, wifi, wlan, or 3g/4g/. etc...
BT comes in 2 power settings, some devices do not use high power mode. (on speakers this would make for best) does the speakers pair with any other PC? with BT?
the speakers if not junk has RTM manual. and read the page on how to reset pairing. BT loves to memorize your favorite devices, so if problems happen. learn how to reset that memory , call reset pairing history.
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
My Samsung AirTrack soundbar was showing my iPhone 5 and my iPhone 5 was showing the soundbar was available. However, when I tried to connect them I got an error saying the connection was unsuccessful. So what I did was "forget device" and then paired them again. It worked right away. I hope this works!
Whenever you connect your bluetooth (BT) headset to a BT device:
Set the BT device to search for other devices.
While the BT device is searching and the BT headset is off, press and hold the call/end button on the BT headset until it's light is constantly lit and the BT device finds it.
