Ok, i want to hook up a vcr/dvd player to my tv/cable box, i want to make tapes of programs i am unable to watch at the time of airing. my tv is a slyvania LD200SL8 LCD WITH built in dvd player. my cable box is a motorola interactive digital communications DCT2000, MY vcr/dvd player is EWR20VR. HOW DO I CONNECT THE WIRES?
    New Friend:
  • 29 Answers
A VCR / DVD player is not a recorder. If it is a recorder you need to advise what input and output ports you have on each of the devices that you wish to connect, then the connection would be from the cable box thro' the recorder and into the TV.
Posted on Nov 22, 2017
6ya staff
SOURCE:
pishta68
Steven Wander
  • 594 Answers
SOURCE: CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Posted on Feb 28, 2008
Anonymous
SOURCE: taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Posted on Jun 12, 2008
Brandon M.
  • 34 Answers
SOURCE: connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 08, 2008
Anonymous
SOURCE: tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Posted on Feb 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
Can get dvd/vcr to work but vcr won't record
first did you program the vcr to match your cable channels ...that needs to be done on most vcrs/dvd/ combos and second if you have a cable box on your tv you still need to run a coax cable from the cable box to the in of the dvd player and out of the dvd player to the tv.
May 14, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I hook up the recorder
Hi....
Take the output of the Satellite box to the "In from antenna" or "in from cable" then out to TV from the VCR to the TV.
TV should either be on 3 or 4 depending on what the satellite box is set for
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Dec 04, 2008 | Televison & Video
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DVP3345V/17 can't watch TV Programs
I would like a insturction book, as I never receiver one. I can't fine the channel on the vcr to match the channel on the tv. to tape. My Name Carol King
Address 229 Billings Ave.
Paulsboro., Nj. 08066 Thanking you
Carol King
Model #DVP3345v/17
Serial #SG1A0816014102 Make Philips VCR/DVD
Aug 16, 2008 | Philips Magnavox DVD/VCR Dual Player
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Hook up
What channel do you have your TV on...3 or 4? Match that setting on your V5500, hit the TV/VCR button and you should have onscreen whatever channel the cable box is on.
Nov 25, 2007 | Samsung DVD-V5500 DVD Player/VCR
Hook-up strategy
OK I will try to explain this...You need to go from your OUT TO TV output on your cable box and split that line so you have 2 lines coming out,then you can hook one to your vcr and one directly to your tv.Then you can watch tv while you are recording something on your VCR.I hope this helps
Sep 24, 2007 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
